Ga door naar hoofdinhoud
Hover-1 Liberty Bottom Cover Replacement
Wat je nodig hebt
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    Vraag FixBot
    Voeg opmerking toe
  2. Hover-1 Liberty Bottom Cover Replacement: stap 2, afbeelding 1 van 2 Hover-1 Liberty Bottom Cover Replacement: stap 2, afbeelding 2 van 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    Vraag FixBot
    Voeg opmerking toe
  3. Hover-1 Liberty Bottom Cover Replacement: stap 3, afbeelding 1 van 3 Hover-1 Liberty Bottom Cover Replacement: stap 3, afbeelding 2 van 3 Hover-1 Liberty Bottom Cover Replacement: stap 3, afbeelding 3 van 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Patrick Bacon
438 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G2, White Fall 2018 Lid van Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Leden
4 handleidingen geschreven
2Gids Commentaar
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Antwoord Deel
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 53
Altijd: 3,679
