Ga door naar hoofdinhoud
Hover-1 Liberty Battery Replacement
Wat je nodig hebt
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    Vraag FixBot
    Voeg opmerking toe
  2. Hover-1 Liberty Battery Replacement: stap 2, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    Vraag FixBot
    Voeg opmerking toe
  3. Hover-1 Liberty Battery Replacement: stap 3, afbeelding 1 van 3 Hover-1 Liberty Battery Replacement: stap 3, afbeelding 2 van 3 Hover-1 Liberty Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  4. Hover-1 Liberty Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
    Vraag FixBot
    Voeg opmerking toe
  5. Hover-1 Liberty Battery Replacement: stap 5, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
    Vraag FixBot
    Voeg opmerking toe
  6. Hover-1 Liberty Battery Replacement: stap 6, afbeelding 1 van 2 Hover-1 Liberty Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
    Vraag FixBot
    Voeg opmerking toe
  7. Hover-1 Liberty Battery Replacement: stap 7, afbeelding 1 van 3 Hover-1 Liberty Battery Replacement: stap 7, afbeelding 2 van 3 Hover-1 Liberty Battery Replacement: stap 7, afbeelding 3 van 3
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Patrick Bacon
438 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G2, White Fall 2018 Lid van Cal Poly, Team S13-G2, White Fall 2018
CPSU-WHITE-F18S13G2
3 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 55
Altijd: 3,284
