Ga door naar hoofdinhoud
Hover-1 H1 Power Button Replacement
Wat je nodig hebt
    1. Hover-1 H1 Power Button  Replacement, Bottom Shell: stap 1, afbeelding 1 van 1
      • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. Hover-1 H1 Power Button  Replacement: stap 2, afbeelding 1 van 1
      • Puncture the two black stickers by using the tip of a screwdriver.
      • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    3. Hover-1 H1 Power Button  Replacement: stap 3, afbeelding 1 van 2 Hover-1 H1 Power Button  Replacement: stap 3, afbeelding 2 van 2
      • Lift each side of the bottom shell by pulling up.
      • When lifting the shell, take care to not tear any cables from their connectors.
      Vraag FixBot
      Voeg opmerking toe
    4. Hover-1 H1 Power Button  Replacement: stap 4, afbeelding 1 van 1
      • Unplug the battery by pulling gently on both sides of the orange connector.
      Vraag FixBot
      Voeg opmerking toe
    1. Hover-1 H1 Power Button  Replacement, Power Button: stap 5, afbeelding 1 van 1
      • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
      • Pull the cable through the center section of the hoverboard.
      • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
      Vraag FixBot
      Voeg opmerking toe
    2. Hover-1 H1 Power Button  Replacement: stap 6, afbeelding 1 van 2 Hover-1 H1 Power Button  Replacement: stap 6, afbeelding 2 van 2
      • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    3. Hover-1 H1 Power Button  Replacement: stap 7, afbeelding 1 van 1
      • Pull the power button through the hole in the shell.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher Bruni
121 Reputatie
1 Handleiding geschreven
Cal Poly, Team S17-G6, White Fall 2018 Lid van Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 4,080
