Inleiding
This guide explains how to replace the LED headlights on your Hover-1 H1 hoverboard.
Wat je nodig hebt
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
Één andere persoon heeft deze handleiding voltooid.
