Inleiding
Replacing in the battery in your Hover-1 H1 hoverboard might help to solve charging problems.
Wat je nodig hebt
Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
5 andere personen hebben deze handleiding voltooid.
15Gids Commentaar
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
