Ga door naar hoofdinhoud
Hover-1 Folding E-Scooter LED Headlight Replacement
Wat je nodig hebt
  1. Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: stap 1, afbeelding 1 van 2 Hover-1 Folding E-Scooter LED Headlight Replacement, LED Headlight: stap 1, afbeelding 2 van 2
    • Face the front of the scooter towards you.
    • Remove all four 24mm bolts by turning counterclockwise using the Hex 4 screwdriver bit.
  2. Hover-1 Folding E-Scooter LED Headlight Replacement: stap 2, afbeelding 1 van 2 Hover-1 Folding E-Scooter LED Headlight Replacement: stap 2, afbeelding 2 van 2
    • Remove the headlight housing.
    • The LED should release when you take off the cover.
    • Be careful when taking off the cover; the light is glued onto the cover and could harm the device.
  3. Hover-1 Folding E-Scooter LED Headlight Replacement: stap 3, afbeelding 1 van 2 Hover-1 Folding E-Scooter LED Headlight Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the red wire using a soldering iron.
    • The soldering iron should melt the glue for you, so don't worry about removing it yourself.
  4. Hover-1 Folding E-Scooter LED Headlight Replacement: stap 4, afbeelding 1 van 1
    • For ease of installation, tin your new LED and the connecting wire with the soldering iron and solder.
    • Solder your new light on to the existing red wire.
    • For help on how to solder, refer to iFixit's Soldering Guide.
Conclusie
To reassemble your device, follow these instructions in reverse order with the new LED.
Nicolo DiFronzo
229 Reputatie
2 handleidingen geschreven
Cal Poly, Team S15-G5, White Fall 2018 Lid van Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 3,213
