Ga door naar hoofdinhoud
Hover-1 Eagle Throttle/Brake Lever Replacement
Wat je nodig hebt
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: stap 1, afbeelding 1 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: stap 1, afbeelding 2 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: stap 1, afbeelding 3 van 3
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: stap 2, afbeelding 1 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement: stap 2, afbeelding 2 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement: stap 2, afbeelding 3 van 3
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: stap 3, afbeelding 1 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement: stap 3, afbeelding 2 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement: stap 3, afbeelding 3 van 3
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: stap 4, afbeelding 1 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement: stap 4, afbeelding 2 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement: stap 4, afbeelding 3 van 3
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: stap 5, afbeelding 1 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement: stap 5, afbeelding 2 van 3 Hover-1 Eagle Throttle/Brake Lever Replacement: stap 5, afbeelding 3 van 3
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Andrew Gaskell
1.008 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G2, White Winter 2020 Lid van Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 Leden
6 handleidingen geschreven
24 opmerkingen
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - Antwoord
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - Antwoord
Necesito acelerador y no lo encuentro.
Josue Villanueva - Antwoord
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 103
Altijd: 15,640
