Inleiding
This guide will walk you through how to replace a faulty or worn-down front wheel on a Hover-1 Eagle scooter. You should replace your front wheel if your front wheel has been worn down or damaged. To determine if you need to replace your front wheel, refer to our Troubleshooting Guide.
Wat je nodig hebt
Wedge the spudger underneath the red reflective sticker and peel it back.
3 andere personen hebben deze handleiding voltooid.
17 opmerkingen
Good afternoon.
And how do you remove the cables?
i would like to know the same thing
where do i get the front wheel front i cant find where to buy a new front wheel
I would like to know as well how to take the cable out from harness. Do you have to remove everything from the battery and disconnect the throttle as well?
