Ga door naar hoofdinhoud
Hover-1 Charger LED Headlight Replacement
Wat je nodig hebt
  1. Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: stap 1, afbeelding 1 van 2 Hover-1 Charger LED Headlight Replacement, Unplugging the Battery: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger LED Headlight Replacement: stap 2, afbeelding 1 van 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger LED Headlight Replacement: stap 3, afbeelding 1 van 2 Hover-1 Charger LED Headlight Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger LED Headlight Replacement: stap 4, afbeelding 1 van 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger LED Headlight Replacement: stap 5, afbeelding 1 van 2 Hover-1 Charger LED Headlight Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger LED Headlight Replacement, LED Headlight: stap 6, afbeelding 1 van 2 Hover-1 Charger LED Headlight Replacement, LED Headlight: stap 6, afbeelding 2 van 2
    • Remove the black and red two pin connector from the circuitboard.
  7. Hover-1 Charger LED Headlight Replacement: stap 7, afbeelding 1 van 2 Hover-1 Charger LED Headlight Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 12mm screws holding the LED to the front cover with a Phillips #2 screwdriver.
    • Our Hoverboard was missing a screw in the LED housing. Yours may or may not be missing screws as well.
  8. Hover-1 Charger LED Headlight Replacement: stap 8, afbeelding 1 van 1
    • With the wire unplugged and screws removed, you can now safely seperate the LED from the Hoverboard.
Conclusie
Benji Forest
266 Reputatie
2 handleidingen geschreven
Cal Poly, Team S12-G1, Regan Fall 2019 Lid van Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 223
