Ga door naar hoofdinhoud
Hover-1 Charger Bluetooth Speaker Replacement
Wat je nodig hebt
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: stap 1, afbeelding 1 van 2 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: stap 1, afbeelding 2 van 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: stap 2, afbeelding 1 van 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: stap 3, afbeelding 1 van 2 Hover-1 Charger Bluetooth Speaker Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: stap 4, afbeelding 1 van 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: stap 5, afbeelding 1 van 2 Hover-1 Charger Bluetooth Speaker Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: stap 6, afbeelding 1 van 1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: stap 7, afbeelding 1 van 2 Hover-1 Charger Bluetooth Speaker Replacement: stap 7, afbeelding 2 van 2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: stap 8, afbeelding 1 van 2 Hover-1 Charger Bluetooth Speaker Replacement: stap 8, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: stap 9, afbeelding 1 van 2 Hover-1 Charger Bluetooth Speaker Replacement: stap 9, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: stap 10, afbeelding 1 van 1
    • Remove the speaker and circuit board from the outer shell.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bryson Shishido
145 Reputatie
1 Handleiding geschreven
Cal Poly, Team S12-G1, Regan Fall 2019 Lid van Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 35
Altijd: 1,335
