Ga door naar hoofdinhoud
Hover 1 Eclipse Motherboard Replacement
Wat je nodig hebt
    1. Hover 1 Eclipse Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Hover 1 Eclipse Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Hover 1 Eclipse Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
      • Using a Phillips #1 Screwdriver, remove the eight 11mm screws that surround the edge of each shell piece.
      • Using a Phillips #1 Screwdriver, remove the eight 13mm screws that surround the edge of both shell pieces.
      • Remove the right side bottom shell piece.
      Vraag FixBot
      Voeg opmerking toe
    2. Hover 1 Eclipse Motherboard Replacement: stap 2, afbeelding 1 van 3 Hover 1 Eclipse Motherboard Replacement: stap 2, afbeelding 2 van 3 Hover 1 Eclipse Motherboard Replacement: stap 2, afbeelding 3 van 3
      • On the bottom, left side, shell pieces, there are some white and pink wires connecting the shell and the motherboard.
      • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
      • Follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
      • Now you can fully remove the bottom left shell piece.
      Vraag FixBot
      Voeg opmerking toe
    3. Hover 1 Eclipse Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Unplug the yellow tipped plug, Xt60, attached to the red and black cord on the non-battery side.
      Vraag FixBot
      Voeg opmerking toe
    4. Hover 1 Eclipse Motherboard Replacement: stap 4, afbeelding 1 van 3 Hover 1 Eclipse Motherboard Replacement: stap 4, afbeelding 2 van 3 Hover 1 Eclipse Motherboard Replacement: stap 4, afbeelding 3 van 3
      • Unplug the yellow tipped plug attached to the red and black cords.
      • Unplug the black headers attached to the white, skinny cord.
      • Unplug the green, blue and yellow plugs by pressing down the silver, under the clear plastic and pulling it apart.
      Vraag FixBot
      Voeg opmerking toe
    5. Hover 1 Eclipse Motherboard Replacement: stap 5, afbeelding 1 van 2 Hover 1 Eclipse Motherboard Replacement: stap 5, afbeelding 2 van 2
      • Unplug the white header attached to the pink and white cord.
      • Using a Phillips #1 screwdriver, remove the four screws from each corner of the motherboard.
      • Repeat steps 3 and 4 on the other side.
      Vraag FixBot
      Voeg opmerking toe
    6. Hover 1 Eclipse Motherboard Replacement: stap 6, afbeelding 1 van 1
      • You have now removed the motherboards from both sides.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Mina Dedijer
548 Reputatie
4 handleidingen geschreven
Cal Poly, Team S12-G4, Regan Fall 2019 Lid van Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Leden
5 handleidingen geschreven
7Gids Commentaar
Can you please drop links to purchase the 2 motherboards?
Frank - Antwoord Deel
Hi
wondering if you know the part numbers and where to obtain the boards?
Dave - Antwoord Deel
We’re do you get the boards at I really need them
Ashton Mcalvain - Antwoord Deel
We’re do get the boards?
Hector Ortiz - Antwoord Deel
Any idea where to buy parts and the price?
william bowen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 2,633
