Ga door naar hoofdinhoud
Hover 1 Eclipse Charging Port Replacement
Wat je nodig hebt
    1. Hover 1 Eclipse Charging Port Replacement, Charging Port: stap 1, afbeelding 1 van 2 Hover 1 Eclipse Charging Port Replacement, Charging Port: stap 1, afbeelding 2 van 2
      • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the left side bottom shell piece.
      • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the left side bottom shell piece.
      • The order and placement of the 2 types of screws is mirrored for both sides of the bottom shell.
      • Pull back and set aside the left bottom shell halve. This shell half is still wired to rest of the hoverboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Hover 1 Eclipse Charging Port Replacement: stap 2, afbeelding 1 van 1
      • Unscrew the ring around the inside section of the charging port.
      Vraag FixBot
      Voeg opmerking toe
    3. Hover 1 Eclipse Charging Port Replacement: stap 3, afbeelding 1 van 1
      • Follow the wire back from the charging port to where it plugs into the board.
      • Unplug the wire from the board, and pull it through the ring you previously unscrewed from the charging port.
      Vraag FixBot
      Voeg opmerking toe
    4. Hover 1 Eclipse Charging Port Replacement: stap 4, afbeelding 1 van 2 Hover 1 Eclipse Charging Port Replacement: stap 4, afbeelding 2 van 2
      • Pull the charging port and wire attached to it out through the front side of the port.
      • Take the plastic protector off of the charging port.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Mina Dedijer
548 Reputatie
4 handleidingen geschreven
Cal Poly, Team S12-G4, Regan Fall 2019 Lid van Cal Poly, Team S12-G4, Regan Fall 2019
CPSU-REGAN-F19S12G4
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 1,104
