Ga door naar hoofdinhoud
Hott T725-8G Battery Replacement
Wat je nodig hebt
  1. Hott T725-8G Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
    Vraag FixBot
    Voeg opmerking toe
  2. Hott T725-8G Battery Replacement: stap 2, afbeelding 1 van 1
    • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
    • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
    Vraag FixBot
    Voeg opmerking toe
  3. Hott T725-8G Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully dislodge the speaker from the back panel.
    Vraag FixBot
    Voeg opmerking toe
  4. Hott T725-8G Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  5. Hott T725-8G Battery Replacement: stap 5, afbeelding 1 van 1
    • Use your fingers to separate the ribbon wire from the battery and the back of the display.
    Vraag FixBot
    Voeg opmerking toe
  6. Hott T725-8G Battery Replacement: stap 6, afbeelding 1 van 1
    • Use your fingers to remove more yellow tape holding down the wire connecting the battery to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Hott T725-8G Battery Replacement: stap 7, afbeelding 1 van 1
    • You can check one of the connection points between the battery and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger. It is not necessary to remove this wire to replace the battery.
    Vraag FixBot
    Voeg opmerking toe
  8. Hott T725-8G Battery Replacement: stap 8, afbeelding 1 van 1
    • Use a Plastic Spudger to separate the adhesive side of the battery from the back of the display.
    • Avoid using metal when working with batteries.
    • The adhesive is extremely sticky, but will separate. Ensure that the battery doesn't bend or fold while removing it.
    Vraag FixBot
    Voeg opmerking toe
  9. Hott T725-8G Battery Replacement: stap 9, afbeelding 1 van 1
    • You may use the plastic Spudger to separate the connections between the battery and motherboard. The new battery is now ready to be soldered on.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Emma Carroll
220 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-2, Martin Fall 2016 Lid van UMass Dartmouth, Team 6-2, Martin Fall 2016
UMASSD-MARTIN-F16S6G2
3 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 673
