Ga door naar hoofdinhoud
Hot Tools HPK12 Control Assembly Replacement
Wat je nodig hebt
  1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: stap 1, afbeelding 1 van 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: stap 1, afbeelding 2 van 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: stap 1, afbeelding 3 van 3
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
    Vraag FixBot
    Voeg opmerking toe
  2. Hot Tools HPK12 Control Assembly Replacement: stap 2, afbeelding 1 van 1
    • Use the metal spudger to push the center pin through to the other side.
    Vraag FixBot
    Voeg opmerking toe
  3. Hot Tools HPK12 Control Assembly Replacement: stap 3, afbeelding 1 van 2 Hot Tools HPK12 Control Assembly Replacement: stap 3, afbeelding 2 van 2
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
    Vraag FixBot
    Voeg opmerking toe
  4. Hot Tools HPK12 Control Assembly Replacement: stap 4, afbeelding 1 van 1
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
    Vraag FixBot
    Voeg opmerking toe
  5. Hot Tools HPK12 Control Assembly Replacement: stap 5, afbeelding 1 van 3 Hot Tools HPK12 Control Assembly Replacement: stap 5, afbeelding 2 van 3 Hot Tools HPK12 Control Assembly Replacement: stap 5, afbeelding 3 van 3
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
    Vraag FixBot
    Voeg opmerking toe
  6. Hot Tools HPK12 Control Assembly Replacement: stap 6, afbeelding 1 van 3 Hot Tools HPK12 Control Assembly Replacement: stap 6, afbeelding 2 van 3 Hot Tools HPK12 Control Assembly Replacement: stap 6, afbeelding 3 van 3
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron Whitlock
249 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-4, Baechle Fall 2016 Lid van IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 31
Altijd: 3,204
