Ga door naar hoofdinhoud
Hoover Power Path Pro Advanced Power Switch Replacement
Wat je nodig hebt
    1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: stap 1, afbeelding 1 van 1
      • Remove the lower brushroll from the bottom of the cleaner.
      Vraag FixBot
      Voeg opmerking toe
    2. Hoover Power Path Pro Advanced Power Switch Replacement: stap 2, afbeelding 1 van 1
      • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
      Vraag FixBot
      Voeg opmerking toe
    3. Hoover Power Path Pro Advanced Power Switch Replacement: stap 3, afbeelding 1 van 2 Hoover Power Path Pro Advanced Power Switch Replacement: stap 3, afbeelding 2 van 2
      • Pull the red handle to remove the front suction unit from the cleaner.
      Vraag FixBot
      Voeg opmerking toe
    4. Hoover Power Path Pro Advanced Power Switch Replacement: stap 4, afbeelding 1 van 1
      • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
      Vraag FixBot
      Voeg opmerking toe
    5. Hoover Power Path Pro Advanced Power Switch Replacement: stap 5, afbeelding 1 van 2 Hoover Power Path Pro Advanced Power Switch Replacement: stap 5, afbeelding 2 van 2
      • Push down on the handle release button. Lift the edge of top cover connected to this button.
      • Repeat the above step for the "On/Off" button.
      • Pull entire top cover off.
      • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
      Vraag FixBot
      Voeg opmerking toe
    6. Hoover Power Path Pro Advanced Power Switch Replacement: stap 6, afbeelding 1 van 1
      • Remove the "On/Off" cap by pulling it upwards with caution.
      Vraag FixBot
      Voeg opmerking toe
    7. Hoover Power Path Pro Advanced Power Switch Replacement: stap 7, afbeelding 1 van 1
      • Use a long #2 Philips head to remove the two screws from the arched grey piece.
      Vraag FixBot
      Voeg opmerking toe
    8. Hoover Power Path Pro Advanced Power Switch Replacement: stap 8, afbeelding 1 van 2 Hoover Power Path Pro Advanced Power Switch Replacement: stap 8, afbeelding 2 van 2
      • Pull out the red power the red power switch.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Cal Poly, Team S16-G5, Banghart Winter 2018 Lid van Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Leden
58 handleidingen geschreven
3Gids Commentaar
What is the part number?
martahayner - Antwoord Deel
Thanks so much!!
debmccrimm - Antwoord Deel
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 50
Altijd: 4,360
