Ga door naar hoofdinhoud
Hoover Power Path Pro Advanced Hose Replacement
Wat je nodig hebt
    1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: stap 1, afbeelding 1 van 2 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: stap 1, afbeelding 2 van 2
      • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
      • Lay the cleaner down horizontally with its wheels closest to the floor.
      Vraag FixBot
      Voeg opmerking toe
    2. Hoover Power Path Pro Advanced Hose Replacement: stap 2, afbeelding 1 van 2 Hoover Power Path Pro Advanced Hose Replacement: stap 2, afbeelding 2 van 2
      • Hold the lower brush roll with both hands and pull outwards until it is detached.
      Vraag FixBot
      Voeg opmerking toe
    3. Hoover Power Path Pro Advanced Hose Replacement: stap 3, afbeelding 1 van 1
      • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
      • Remove the brush roller.
      Vraag FixBot
      Voeg opmerking toe
    1. Hoover Power Path Pro Advanced Hose Replacement, Hose: stap 4, afbeelding 1 van 1
      • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
      • They will also be indicated on the bottom of the vacuum.
      Vraag FixBot
      Voeg opmerking toe
    2. Hoover Power Path Pro Advanced Hose Replacement: stap 5, afbeelding 1 van 2 Hoover Power Path Pro Advanced Hose Replacement: stap 5, afbeelding 2 van 2
      • Pull the red handle shown to remove the front suction unit from the cleaner.
      Vraag FixBot
      Voeg opmerking toe
    3. Hoover Power Path Pro Advanced Hose Replacement: stap 6, afbeelding 1 van 1
      • Unscrew the Phillips #2 screw at the bottom of the hose.
      Vraag FixBot
      Voeg opmerking toe
    4. Hoover Power Path Pro Advanced Hose Replacement: stap 7, afbeelding 1 van 1
      • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Cal Poly, Team S16-G5, Banghart Winter 2018 Lid van Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 Leden
61 handleidingen geschreven
4Gids Commentaar
Where can I find this replacement hose?
Jennifer - Antwoord Deel
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - Antwoord Deel
Where can I purchase the lower hose?
Eryk H. - Antwoord Deel
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 35
Altijd: 5,136
