Ga door naar hoofdinhoud
Honeywell Turbo Force Air Circulator Fan Disassembly
Wat je nodig hebt
  1. Honeywell Turbo Force Air Circulator Fan Disassembly, Overview: stap 1, afbeelding 1 van 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Overview: stap 1, afbeelding 2 van 2
    • Honeywell Turbo Force 12" Air Circulator.
    • Dimensions - 11.22" x 9.8" x 13.98", 5.7 lbs.
  2. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Scews: stap 2, afbeelding 1 van 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Scews: stap 2, afbeelding 2 van 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Scews: stap 2, afbeelding 3 van 3
    • Remove the 6 screws from the backside of the fan.
  3. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the grill: stap 3, afbeelding 1 van 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the grill: stap 3, afbeelding 2 van 2
    • Remove the front grill cover.
    This is a lot harder than it looks at first. I believe that some models may have a metal ring, and that can make the removal 10 times harder. The only way I was able to remove the ring was to take a small screwdriver and bend one of the flaps up until the ring had enough room to be pried out.
    Noah - Antwoord
  4. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the plastic ring: stap 4, afbeelding 1 van 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the plastic ring: stap 4, afbeelding 2 van 2
    • Remove the inside plastic ring around center shaft.
    • Enables the fan blades to be removed.
    • Use a flat head screwdriver to remove the plastic ring.
  5. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Fan blades: stap 5, afbeelding 1 van 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Fan blades: stap 5, afbeelding 2 van 2
    • Remove the fan blades by pulling.
  6. Honeywell Turbo Force Air Circulator Fan Disassembly, Detaching wire covering: stap 6, afbeelding 1 van 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Detaching wire covering: stap 6, afbeelding 2 van 2
    • Remove 1 screw inside to detach the plastic wire covering.
  7. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the wire protector piece: stap 7, afbeelding 1 van 1
    • Remove the plastic covering.
  8. Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: stap 8, afbeelding 1 van 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: stap 8, afbeelding 2 van 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: stap 8, afbeelding 3 van 3
    • Remove the 2 screws on the motor.
    • This allows the motor to pull away from the housing.
  9. Honeywell Turbo Force Air Circulator Fan Disassembly, Pulling the Motor from the Housing: stap 9, afbeelding 1 van 1
    • Pull the motor away from the housing to expose wiring.
    • Use caution to not detach the wiring from the back.
  10. Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the Rotor: stap 10, afbeelding 1 van 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the Rotor: stap 10, afbeelding 2 van 2
    • Remove the two screws from the back of the motor.
    • Allows the rotor and front/back bearings to be removed.
  11. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the Rotor: stap 11, afbeelding 1 van 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the Rotor: stap 11, afbeelding 2 van 2
    • Remove the rotor and front bearings by pulling.
  12. Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: stap 12, afbeelding 1 van 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: stap 12, afbeelding 2 van 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: stap 12, afbeelding 3 van 3
    • During reassembly, re-align the bearings by tapping on the shaft.
Conclusie
To reassemble the fan, follow these instructions in reverse order. Note that Step 12 is an extra step in the reassembly process to follow.
5 andere personen hebben deze handleiding voltooid.
Donovan Williams
352 Reputatie
1 Handleiding geschreven
5Gids Commentaar
Thank you for the good guide, I saved my fan in the middle of hot weather!
Noah - Antwoord
I have a Honeywell HF910. I have taken the cover off but there are no screws behind the fan blades. Any suggestions on how to remove the fan blades? Thank you.
Nancy Alexander - Antwoord
I have a hf710 turbo fan I need the screws can I find out the size of them there the ones holding the cover on
Janet hicks - Antwoord
Thank You for the detailed guide. I couldn't get the ring off, other than that Perfect.
Paula L Burnett - Antwoord
I have a Honeywell HF 810 series fan. I’ve watched both your videos on the 800 and 900 series. I have a problem with the front grill releasing. I’ve taken out all 10 screws and been able to loosen it all the way around, forcefully with screw drivers but it won’t release. It is like the motor is attached to the Front/back grill.Help!
Joan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 111
Afgelopen 30 dagen: 524
Altijd: 13,636
