Ga door naar hoofdinhoud
Honda CR-V Touring 2016 Cabin Air Filter Replacement
Wat je nodig hebt
  1. Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 1 van 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 2 van 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 3 van 3
    • Ensure that your 2016 Honda CR-V Touring Edition is off.
    • Open the glovebox and remove all of its contents.
  2. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 2, afbeelding 1 van 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 2, afbeelding 2 van 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 2, afbeelding 3 van 3
    • Unfasten the hinge on the right side of your glovebox so the hook-part of the hinge is free and clear.
    • You may have to close the glovebox slightly, then open it fully while holding the hook to clear it.
  3. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 3, afbeelding 1 van 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 3, afbeelding 2 van 2
    • Push both sides of the glovebox together while lowering until the glovebox hangs at its lowest point.
    • This should allow access to the interior and give a clear line of sight to the cabin air filter holder.
  4. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 4, afbeelding 1 van 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 4, afbeelding 2 van 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 4, afbeelding 3 van 3
    • Grasp both clasps on either side of the rectangular cabin air filter protective cover and pull to release the cover.
    • You should see a white filter.
  5. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 5, afbeelding 1 van 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 5, afbeelding 2 van 2
    • Pull the filter straight out until it is free and clear.
    • Be sure not to shake it to prevent any excess dust from falling.
  6. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 6, afbeelding 1 van 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 6, afbeelding 2 van 3 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 6, afbeelding 3 van 3
    • Insert the new filter, taking care to orient the filter in the correct direction for airflow.
    • It will be marked with arrows both on the filter and below the location for the filter.
  7. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 7, afbeelding 1 van 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 7, afbeelding 2 van 2
    • Place the cabin air filter protective cover over top of the filter until you hear audible clicks from the clasps engaging.
  8. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 8, afbeelding 1 van 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 8, afbeelding 2 van 2
    • Push the glovebox up until you feel a detent where it is self supported but is not fully in the up-position.
  9. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 9, afbeelding 1 van 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 9, afbeelding 2 van 2
    • Re-clip the hook on the right side of the glovebox until it is fully engaged.
  10. Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 10, afbeelding 1 van 2 Honda CR-V Touring 2016 Cabin Air Filter Replacement: stap 10, afbeelding 2 van 2
    • Close the glovebox and you're all set!
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 34
Altijd: 1,601
