Inleiding
If the arm of the drone is having trouble opening or is broken, you will need to replace the arm. The arm of the drone holds the propeller blades and allows the propeller to spin, without the arm the drone is inoperable.
The only tool needed to replace the arm is a Phillips #0 screwdriver. This replacement is simple and prompt, these are the steps to accomplish this task.
Wat je nodig hebt
Start by removing the 2 mm Phillips #0 screw, located right under the base of the arm.
After removing the screw, dispose of the old arm.
Purchase a new arm from the HolyStone product page as the replacement for the old arm.
