Ga door naar hoofdinhoud
Hitachi CP-X440 Sensor Replacement
Wat je nodig hebt
  1. Hitachi CP-X440 Sensor Replacement, Sensor: stap 1, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the six 2 cm screws from the bottom of the case.
    Vraag FixBot
    Voeg opmerking toe
  2. Hitachi CP-X440 Sensor Replacement: stap 2, afbeelding 1 van 2 Hitachi CP-X440 Sensor Replacement: stap 2, afbeelding 2 van 2
    • Flip the projector back upright and place the back of projector towards you. Unscrew the 3 screws circled in the back with your Phillips #1 Screwdriver. Each screw is 1 cm in length.
    • Then unscrew the two silver, 1 cm screws on the light switch panel with a Phillips #1 Screwdriver
    Vraag FixBot
    Voeg opmerking toe
  3. Hitachi CP-X440 Sensor Replacement: stap 3, afbeelding 1 van 3 Hitachi CP-X440 Sensor Replacement: stap 3, afbeelding 2 van 3 Hitachi CP-X440 Sensor Replacement: stap 3, afbeelding 3 van 3
    • You will now be able to pop the top of the projector off.
    • To uncollapse the projector top fully from the projector, you can pull the black cord from the white holder near the lens, circled in red and orange.
    • With front of projector now facing you, the sensor can be found on the left of the lens.
    Vraag FixBot
    Voeg opmerking toe
  4. Hitachi CP-X440 Sensor Replacement: stap 4, afbeelding 1 van 2 Hitachi CP-X440 Sensor Replacement: stap 4, afbeelding 2 van 2
    • The sensor will be held into the projector by a silver screw on the lower left side of lens. This single 2 mm screw will need to be unscrewed and removed. This will allow you to remove the sensor piece completely out of the projector.
    • You now will remove the sensor piece completely.
    Vraag FixBot
    Voeg opmerking toe
  5. Hitachi CP-X440 Sensor Replacement: stap 5, afbeelding 1 van 3 Hitachi CP-X440 Sensor Replacement: stap 5, afbeelding 2 van 3 Hitachi CP-X440 Sensor Replacement: stap 5, afbeelding 3 van 3
    • To get the sensor piece alone, you will unscrew the single 3 mm silver screw.
    • Once this screw in the sensor piece is removed, the sensor piece will be alone and can be replaced with your new one.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Natalie Safron
221 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 371
