Ga door naar hoofdinhoud
Hisense Sero 8 Motherboard Replacement
Wat je nodig hebt
  1. Hisense Sero 8 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Hisense Sero 8 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Hisense Sero 8 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Remove the back cover of the device using the plastic opening tool.
    • Pry open a corner of the device, then continue down the side with the tool to open the device.
  2. Hisense Sero 8 Motherboard Replacement: stap 2, afbeelding 1 van 2 Hisense Sero 8 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the black tape located to the left of the device.
    • Remove the clear tape directly below the camera.
  3. Hisense Sero 8 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the seven 4.43mm screws located at the top of the device using the Phillips #00 screwdriver.
    • There is no need to remove the bottom two screws holding the speakers in place.
  4. Hisense Sero 8 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unlock the three ribbon cable connector latches to remove the cables.
  5. Hisense Sero 8 Motherboard Replacement: stap 5, afbeelding 1 van 3 Hisense Sero 8 Motherboard Replacement: stap 5, afbeelding 2 van 3 Hisense Sero 8 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Be cautious of the extremely hot tip of the soldering iron.
    • Desolder the red, black, and yellow wires to remove the motherboard. Take a look at this guide to learn how to solder and desolder connections.
    • Desolder the black wire located on the top left of the device.
    • Once desoldered, carefully lift the motherboard out of the device.
Conclusie
Katharina
506 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-2, Leahy Winter 2015 Lid van USF Tampa, Team 1-2, Leahy Winter 2015
USFT-LEAHY-W15S1G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 1,355
