Ga door naar hoofdinhoud
Hipstreet Equinox 2 Screen Replacement
Wat je nodig hebt
  1. Hipstreet Equinox 2 Screen Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Screen Replacement: stap 2, afbeelding 1 van 1
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Screen Replacement, Battery: stap 3, afbeelding 1 van 1
    • Disconnect the wires that connect the battery to the motherboard using the spudger.
  4. Hipstreet Equinox 2 Screen Replacement: stap 4, afbeelding 1 van 1
    • Slide the spudger underneath the battery and gently lift it off of the adhesive.
  5. Hipstreet Equinox 2 Screen Replacement: stap 5, afbeelding 1 van 2 Hipstreet Equinox 2 Screen Replacement: stap 5, afbeelding 2 van 2
    • Place the new battery in the same location and connect the wires the same way as the previous battery.
  6. Hipstreet Equinox 2 Screen Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Unsolder these wires from the motherboard, it is a good idea to label these wires as you remove them according to the picture to the left.
  7. Hipstreet Equinox 2 Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove contact strips by lifting gently on the clip indicated in this picture, then pulling strip out of the clip.
  8. Hipstreet Equinox 2 Screen Replacement: stap 8, afbeelding 1 van 1
    • Remove the 3.5mm screws located at these locations shown on the picture by using the PH00 screwdriver.
  9. Hipstreet Equinox 2 Screen Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the motherboard out of the tablet, make sure no wires are still caught or attached while you lift the motherboard.
  10. Hipstreet Equinox 2 Screen Replacement, Screen: stap 10, afbeelding 1 van 1
    • Remove these 2.5mm screws and brackets holding the screen down using a PH00 screwdriver.
  11. Hipstreet Equinox 2 Screen Replacement: stap 11, afbeelding 1 van 1
    • Gently lift the screen out of the tablet
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brandon Snodgrass
410 Reputatie
4 handleidingen geschreven
Clemson, Team 15-8, Shirley Winter 2015 Lid van Clemson, Team 15-8, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G8
5 Leden
12 handleidingen geschreven
Één opmerking
OK, so I cracked my screen and I cracked it today so I went on there to do the usual, you know? Well when I turned it on, my password lock started bugging out! (I thought a was being hacked) I am worried to do this (Step - Step thing) because I am just a child (NOT A SMALL ONE DON'T REALLY WORRY!) and my parents will be disappointed in me, I got this for my birthday! But this one is a white HipStreet tablet, one of those fancy new ones, I checked it out to see if it was actually a crack so I took off my screen protector and I felt it, but no, no! It was a crack but I couldn't feel it! I thought it was REALLY in the tablet, like through the hard-drive and wires and stuff like that, please help me I don't want to get in trouble, I can't really afford another one, and my parents say "You better protect this with your entire life, because if you break this one..YOU WON'T GET ANOTHER!" (I had 2 tablets along time ago, I broke them both, OH PLEASE I WAS A SMALL CHILD!) So please help me, Thank - You!
N3rD Al3rT - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 901
