Inleiding
If you need to replace the volume knob of your Heyday Suitcase Turntable, follow this repair guide. If the volume knob has no affect on sound level, it likely needs to be replaced.
Before beginning your repair, be sure to turn off the record player and unplug the power cord.
This guide requires soldering so if you aren't familiar or need a refresher, take a look at the guide for How to Solder and Desolder Connections. Be careful when soldering as the iron is very hot and will burn skin and other items.
Wat je nodig hebt
Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
