Ga door naar hoofdinhoud
Heyday Suitcase Turntable Belt Replacement
Wat je nodig hebt
    1. Heyday Suitcase Turntable Belt Replacement, Platter: stap 1, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      $3.99
      • Unlock the front latches and open the turntable suitcase cover.
      • Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
      • Be careful, as the spindle shaft may fly off in an unexpected direction.
      Vraag FixBot
      Voeg opmerking toe
    2. Heyday Suitcase Turntable Belt Replacement: stap 2, afbeelding 1 van 1
      • Use both hands to gently lift the platter up and off of the turntable.
      Vraag FixBot
      Voeg opmerking toe
    1. Heyday Suitcase Turntable Belt Replacement, Belt: stap 3, afbeelding 1 van 1
      • Flip the platter over.
      • Pull the belt off from the edge of the platter.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. After removing the old belt, replace it by attaching the new belt around the platter. Then, put the platter and the spindle shaft back to its original place. Feel free to refer to the platter replacement guide if necessary.
Caroline D'Amato
565 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 2-1, Petersen Fall 2022 Lid van UMass Dartmouth, Team 2-1, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G1
4 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 916
