Ga door naar hoofdinhoud
Heating Element Contacts
Wat je nodig hebt
  1. Heating Element Contacts, Heating Element Contacts: stap 1, afbeelding 1 van 3 Heating Element Contacts, Heating Element Contacts: stap 1, afbeelding 2 van 3 Heating Element Contacts, Heating Element Contacts: stap 1, afbeelding 3 van 3
    • Before you begin, be sure to unplug your coffee maker.
    • Flip the coffee maker over so the bottom is facing upwards.
    • Use the T10 Torx screwdriver to remove all four 17 mm-long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
  2. Heating Element Contacts: stap 2, afbeelding 1 van 2 Heating Element Contacts: stap 2, afbeelding 2 van 2
    • If heating element contacts are disconnected, use soldering iron with soldering wire to re-bond the contacts.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Austin Wheaton
861 Reputatie
4 handleidingen geschreven
UW Stout, Team S8-G1, Ogden Spring 2018 Lid van UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Leden
5 handleidingen geschreven
Één opmerking
Cuisinart Drip Coffee Maker:
Model CBC-6500PCC
In use:
Less than one year.
Problem:
Not heating
Cause:
Blown thermal fuse (240C) connected in series with one side of heating element (there are two, each one connected in series and attached directly to each side of the heating element.) Not replaceable by itself.
Remedy:
Replacement under warranty or purchase a used one at Goodwill, Salvation Army, Value Village, local online personal seller, etc.
brian.steven.richmond - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 29
Altijd: 3,045
