Ga door naar hoofdinhoud
Headset Adjustment
Wat je nodig hebt
    1. Headset Adjustment, Headset Adjustment: stap 1, afbeelding 1 van 1
      • To start the adjustment process first loosen the stem steerer clamp bolts.
      Vraag FixBot
      Voeg opmerking toe
    2. Headset Adjustment: stap 2, afbeelding 1 van 2 Headset Adjustment: stap 2, afbeelding 2 van 2
      • If you feel a knocking sensation when pulling the front brake and rocking the handlebars forward and back, then the headset needs to be tightened.
      • Turning the handlebars 90 degrees and repeating the process can help to ensure that any knocking sensations are not coming from play within the brake mechanism.
      Vraag FixBot
      Voeg opmerking toe
    3. Headset Adjustment: stap 3, afbeelding 1 van 2 Headset Adjustment: stap 3, afbeelding 2 van 2
      • Torque the bearing preload adjustment bolt on your stem cap just enough so that the knocking goes away.
      • Torque required is usually in the 2-3nm range.
      • If the steering feels rough or sluggish after tightening down the headset bearing preload bolt when turning your handlebars from side to side, you’ve over-tightened the headset.
      • Back it off an eighth or a quarter of a turn and check it again by turning the handlebars from side to side and pulling the front brake and rocking the handlebars front to back to feel for any knocking.
      Vraag FixBot
      Voeg opmerking toe
    4. Headset Adjustment: stap 4, afbeelding 1 van 1
      • If no amount of tightening eliminates the knocking, add a two or five millimeter spacer under your headset top cap to increase the available range of adjustment.
      Vraag FixBot
      Voeg opmerking toe
    5. Headset Adjustment: stap 5, afbeelding 1 van 1
      • Once you get a smooth steering feel without any knocking when performing the front brake test, your done with the adjustment and it is time to tighten the stem steerer clamping bolts.
      • Align the stem with the front wheel and torque the steerer clamp bolts to the manufacturer’s recommended torque spec.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Daniel Slusser
349 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 45
Altijd: 452
