Ga door naar hoofdinhoud
Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement
Wat je nodig hebt
  1. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Find the location of the damaged speaker. The speaker can be located above the battery pack on the forearm.
    • Find the damaged wire. It must be replaced with a new one.
  2. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: stap 2, afbeelding 1 van 2 Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: stap 2, afbeelding 2 van 2
    • Desolder the damaged wire from the speaker and replace it with a new one.
    • It will be beneficial to use the wire stripping tool in order to do this.
  3. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: stap 3, afbeelding 1 van 1
    • Once the new wire is attached to the speaker, it must then be reattached to the circuit board.
    • Once the new wires are securely placed in the correct spot, the hand can be put back together.
Conclusie
Tori Mariano
347 Reputatie
1 Handleiding geschreven
Marist, Team 1-3, Chaterdon Spring 2023 Lid van Marist, Team 1-3, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G3
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 66
