Ga door naar hoofdinhoud
Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement
Wat je nodig hebt
    1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: stap 1, afbeelding 1 van 3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: stap 1, afbeelding 2 van 3 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, Batteries: stap 1, afbeelding 3 van 3
      • Find the removable panel at the bottom of the hand.
      • Use your finger to push upwards and open the panel.
      • Slide the panel off and separate it from the hand.
      Vraag FixBot
      Voeg opmerking toe
    2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: stap 2, afbeelding 1 van 2 Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: stap 2, afbeelding 2 van 2
      • Remove the left-most battery by pushing down on the positive end and pulling it out.
      • Repeat this for the next two batteries.
      Vraag FixBot
      Voeg opmerking toe
    1. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement, LED Lights: stap 3, afbeelding 1 van 1
      • Remove the screws within the gauntlet and surrounding the palm.
      Vraag FixBot
      Voeg opmerking toe
    2. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: stap 4, afbeelding 1 van 1
      • Open the gauntlet carefully, as there are wires connecting both sides.
      • Address which LED is faulty. Check if the wires connecting to it are all intact; If there is a detachment within the circuits, reconnect it to its location. The LED should operate in that instance.
      Vraag FixBot
      Voeg opmerking toe
    3. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: stap 5, afbeelding 1 van 1
      • To replace the LED chip, remove the screw holding the chip in place.
      Vraag FixBot
      Voeg opmerking toe
    4. Hasbro Iron Man Infinity Nano Gauntlet LED Lights Guide Replacement: stap 6, afbeelding 1 van 1
      • Ensure that the LED chip is in the correct area with the correct polarity.
      • Reconnect it to its respective surface and check if it fits with in the magnetic gem. If not, consider another replacement.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jessica
109 Reputatie
1 Handleiding geschreven
Marist, Team 1-3, Chaterdon Spring 2023 Lid van Marist, Team 1-3, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G3
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 693
