Ga door naar hoofdinhoud
Harman Kardon Esquire Mini External Stand Replacement
Wat je nodig hebt
  1. Harman Kardon Esquire Mini External Stand  Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
    Vraag FixBot
    Voeg opmerking toe
  2. Harman Kardon Esquire Mini External Stand  Replacement: stap 2, afbeelding 1 van 1
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  3. Harman Kardon Esquire Mini External Stand  Replacement, External Stand: stap 3, afbeelding 1 van 1
    • Using the Pentalobe screw driver, unscrew the 5.1 mm screws by applying a clockwise force.
    • Remove all of the 5.1 mm screws, and slowly lift the stand. There are 4 screws on the stand.
    • After the stand is removed, replace the stand with a new one.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
yousef aljeemaz
1.066 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G9, Cagle Fall 2017 Lid van USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
5 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 961
