Ga door naar hoofdinhoud
Hard / Factory Reset
Video overzicht
    1. Hard / Factory Reset, Hard Reset - Method One:: stap 1, afbeelding 1 van 3 Hard / Factory Reset, Hard Reset - Method One:: stap 1, afbeelding 2 van 3 Hard / Factory Reset, Hard Reset - Method One:: stap 1, afbeelding 3 van 3
      • Switch off the phone.
      • Pres the Power button and when you feel a vibration release it and press and hold the Volume Up button.
      • From Boot mode menu select [Recovery mode] (use Volume Up for navigation and volume doun for OK).
      • Now you are in the known Android System recovery menu. Use again the Volume Up for navigation and the Volume Down for OK and select one by one: wipe data/factory reset - Yes -- delete all user data - reboot system now.
      • Tis will reboot the device and will restore to its default settings.
      Vraag FixBot
      Voeg opmerking toe
    2. Hard / Factory Reset, Factory Reset - Method Two: stap 2, afbeelding 1 van 3 Hard / Factory Reset, Factory Reset - Method Two: stap 2, afbeelding 2 van 3 Hard / Factory Reset, Factory Reset - Method Two: stap 2, afbeelding 3 van 3
      • Press the Power button and wen you fill the vibration, release the Power button and press and hold the Volume Down button.
      • Now the device is in Factory mode. Use the Volume Up/Down buttons for movement and the Power button for OK and select Clear eMMC.
      • That's all. The phone will reboot and will be restored to a factory settings.
      • Did you do it successfully?
      Vraag FixBot
      Voeg opmerking toe
Conclusie
29 andere personen hebben deze handleiding voltooid.
ZFix
197.378 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
334 Leden
3.432 handleidingen geschreven
22Gids Commentaar
great simple clear instructions - did exactly what you said - phone back up and running good as new! Thanks. M
Marty - Antwoord Deel
Thanks. The phone has reset.
melandart - Antwoord Deel
“eMMC is busy can't format, please retry”
What do we do?
richterrea - Antwoord Deel
Today I also met this message. How did you solve this problem? Thanks, Zoltan (HUN)
Zoltán Bocskai - Antwoord Deel
HI!, I did the “clear eMMc” method but still my MePop_V03 phone still stock on logo screen.
what should I do?
Please help me .thanks in advance God bless
Herbert Redondo - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 94
Afgelopen 30 dagen: 350
Altijd: 56,440
