Ga door naar hoofdinhoud
Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement
Wat je nodig hebt
  1. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 2, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 3, afbeelding 1 van 1
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 4, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 4, afbeelding 2 van 2
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 5, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 5, afbeelding 2 van 2
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Battery: stap 6, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Battery: stap 6, afbeelding 2 van 2
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 7, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 7, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 8, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 8, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 8, afbeelding 3 van 3
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 9, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 9, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 9, afbeelding 3 van 3
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
  10. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Front and Rear Camera Replacement: stap 10, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Front and Rear Camera Replacement: stap 10, afbeelding 2 van 2
    • Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
    • The two cameras are connected with one ribbon cable.
    • Zero insertion force connector.
  11. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 11, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 11, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
  12. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 12, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 12, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 12, afbeelding 3 van 3
    • Pull the cameras out of their resting places in a straight upward motion.
  13. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: stap 13, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: stap 13, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement, Left and Right Speaker: stap 13, afbeelding 3 van 3
    • Identify the speakers.
    • Use a pair of tweezers to peel the adhesive tape holding the speaker wires down.
  14. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 14, afbeelding 1 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 14, afbeelding 2 van 3 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 14, afbeelding 3 van 3
    • Desolder the red and black wire to the left and the right of the ZIF connector.
    • Remember the placement of both wires.
    • Both the soldering iron and the wires will be hot.
  15. Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 15, afbeelding 1 van 2 Hannspree Hannspad SN1AT71 Left and Right Speaker Replacement: stap 15, afbeelding 2 van 2
    • Remove the right and left speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
matthew vandeventer
950 Reputatie
5 handleidingen geschreven
Colorado Springs, Team 9-4, Panko Spring 2015 Lid van Colorado Springs, Team 9-4, Panko Spring 2015
UCCS-PANKO-S15S9G4
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 472
