Ga door naar hoofdinhoud
Handspring Visor Edge Screen Replacement
Wat je nodig hebt
  1. Handspring Visor Edge Screen Replacement, Flip Cover: stap 1, afbeelding 1 van 2 Handspring Visor Edge Screen Replacement, Flip Cover: stap 1, afbeelding 2 van 2
    • Open the Visor Edge placing the screen and the inner part of the flip cover face down on a flat surface such as a table
    • On the back of the PDA there is a tab connecting the flip cover to the device. Push gently on this tab trying to slide the cover upwards along the surface then lift the pieces apart to fully detach them
    • Do not pull or tug on the flip cover in an attempt to remove it from the PDA this can result in the cover snapping causing damage to the device
    • To reassemble push the downward on the flip cover where there is an indent on the PDA indicating where the pieces connect. Finally, push the cover until it snaps into place.
  2. Handspring Visor Edge Screen Replacement, Back Panel: stap 2, afbeelding 1 van 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Screen Replacement: stap 4, afbeelding 1 van 2 Handspring Visor Edge Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Screen Replacement: stap 5, afbeelding 1 van 2 Handspring Visor Edge Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Screen Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Screen Replacement, Screen: stap 7, afbeelding 1 van 1
    • Place the PDA front face up.
    • Gently pull off the front cover.
  8. Handspring Visor Edge Screen Replacement: stap 8, afbeelding 1 van 2 Handspring Visor Edge Screen Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Flip over the PDA.
    • Use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
  9. Handspring Visor Edge Screen Replacement: stap 9, afbeelding 1 van 2 Handspring Visor Edge Screen Replacement: stap 9, afbeelding 2 van 2
    • Wedge the spudger in between the glass and the metal frame.
    • Slide the spudger down the length of the screen to detach from the frame.
    • With your hands, pry the screen up from the detached side. The screen will pop off.
Conclusie
Christian Valoria
229 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-28, Maness Winter 2011 Lid van Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,609
