Inleiding
Having problems with audio? Your speaker might not be working well! Read this guide to find out how you can fix that! :)
Wat je nodig hebt
After removing the BP-T18 battery pack, you will see two 11mm Phillips #0 screws located at the bottom of the phone. Remove both screws with a screwdriver.
Use a screwdriver to remove the three 7mm Phillips #0 screws holding the speaker in place.
Solder your replacement speaker into the circuit. For assistance with soldering refer to iFixit Solder and Desolder Guide.
