Inleiding
Replacement of the drive motor. Be sure device is unplugged before beginning replacement.
Wat je nodig hebt
Using a #2 Phillips head screwdriver, remove the two 11 mm screws and pull the rubber suction cups straight up.
Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor.
Using the wire stripper crimping tool strip the ends of each of the black cords and insert them into the opposite ends of a parallel connector, then crimp firmly.
Using the wire stripper crimping tool cut the four red wire connections from the switch to the motor and then rewire the four red wires together in a wiring connector cap.
Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
Één andere persoon heeft deze handleiding voltooid.
