Ga door naar hoofdinhoud
Hamilton Beach 51101BA Power Button Replacement
Wat je nodig hebt
    1. Hamilton Beach 51101BA Power Button Replacement, Power Button: stap 1, afbeelding 1 van 3 Hamilton Beach 51101BA Power Button Replacement, Power Button: stap 1, afbeelding 2 van 3 Hamilton Beach 51101BA Power Button Replacement, Power Button: stap 1, afbeelding 3 van 3
      • Remove the container from the base.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      Vraag FixBot
      Voeg opmerking toe
    2. Hamilton Beach 51101BA Power Button Replacement: stap 2, afbeelding 1 van 1
      • Turn the blender so the bottom is facing you.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
      Vraag FixBot
      Voeg opmerking toe
    3. Hamilton Beach 51101BA Power Button Replacement: stap 3, afbeelding 1 van 1
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
      Vraag FixBot
      Voeg opmerking toe
    4. Hamilton Beach 51101BA Power Button Replacement: stap 4, afbeelding 1 van 2 Hamilton Beach 51101BA Power Button Replacement: stap 4, afbeelding 2 van 2
      • Unhinge the motor platform from the blender.
      • You may need a plastic spudger to unhinge the plastic bottom piece from the base of the blender.
      • You do not need to completely remove this piece from the base.
      Vraag FixBot
      Voeg opmerking toe
    5. Hamilton Beach 51101BA Power Button Replacement: stap 5, afbeelding 1 van 1
      • Pull out the rectangular green piece.
      • This is the actual power button.
      Vraag FixBot
      Voeg opmerking toe
    6. Hamilton Beach 51101BA Power Button Replacement: stap 6, afbeelding 1 van 1
      • Some experience in soldering is required!
      • On the back of the power button, desolder the red and grey wires that are connected to the piece.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Brandon Nunez
301 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-5, Sullivan Fall 2015 Lid van USF Tampa, Team 2-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G5
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 4,033
