Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide to installa replacement heating element if your hairdryer just isn't drying your hair the way it used to.
Onderdelen
Geen onderdelen opgegeven.
  1. Identify the black air concentrating nozzle.
    • Identify the black air concentrating nozzle.
  2. Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
  3. Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • The purpose of this guide is to demonstrate the repair steps for a generic hair dryer. We do not specify screw sizes because screw sizes can differ between hair dryers. For most hair dryers, use a Phillips #1 Screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 Screwdriver.
  4. Detach the hair dryer grating from the body by gently twisting the grating from side to side.
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  5. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  6. Separate the hair dryer grating into the three pieces seen in the image.
    • Separate the hair dryer grating into the three pieces seen in the image.
  7. Locate the screws on the handle and remove them with a Phillips screwdriver
    • Locate the screws on the handle and remove them with a Phillips screwdriver
  8. Carefully separate the plastic case using the Plastic Opening Tools
    • Carefully separate the plastic case using the Plastic Opening Tools
  9. Your hairdryer should now be disassembled. You should easily be able to see the fan, motor, heating element cover, and internal wiring.
    • Your hairdryer should now be disassembled. You should easily be able to see the fan, motor, heating element cover, and internal wiring.
  10. Remove the heat-element housing by sliding it off of the dryer.
    • Remove the heat-element housing by sliding it off of the dryer.
  11. Isolate the heating element. Use a desoldering wick and soldering iron to desolder the wires. Refer to the soldering page below.
    • Isolate the heating element. Use a desoldering wick and soldering iron to desolder the wires. Refer to the soldering page below.
    • Soldering Skills
Conclusie
7 andere personen hebben deze handleiding voltooid.
Mitch
31 Reputatie
5 handleidingen geschreven
Cal Poly, Team 24-29, Regan Fall 2012 Lid van Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 207
Altijd: 32,976
