Ga door naar hoofdinhoud
HVAC Filter Replacement
Wat je nodig hebt
  1. HVAC Filter Replacement, Filter: stap 1, afbeelding 1 van 1
    • Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
    Vraag FixBot
    Voeg opmerking toe
  2. HVAC Filter Replacement: stap 2, afbeelding 1 van 1
    • Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
    • The screws in this vent are phillips hex head screws that are 1 3/4 in. long.
    Vraag FixBot
    Voeg opmerking toe
  3. HVAC Filter Replacement: stap 3, afbeelding 1 van 1
    • Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
    Vraag FixBot
    Voeg opmerking toe
  4. HVAC Filter Replacement: stap 4, afbeelding 1 van 1
    • Remove the vent cover to access the ventilation filter.
    Vraag FixBot
    Voeg opmerking toe
  5. HVAC Filter Replacement: stap 5, afbeelding 1 van 1
    • Optional: Put on a latex glove on the hand that you will use to remove the filter.
    Vraag FixBot
    Voeg opmerking toe
  6. HVAC Filter Replacement: stap 6, afbeelding 1 van 1
    • Remove the filter carefully.
    • Make sure to remove it slowly so that the dust does not come of it.
    Vraag FixBot
    Voeg opmerking toe
  7. HVAC Filter Replacement: stap 7, afbeelding 1 van 1
    • Dispose of the old filter in a waste bin.
    Vraag FixBot
    Voeg opmerking toe
  8. HVAC Filter Replacement: stap 8, afbeelding 1 van 1
    • Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
    • The dimensions for filters will vary depending on the dimensions of the vent.
    • In this case, my vent was 14x25x1 and thus needed a filter with the same dimensions.
    Vraag FixBot
    Voeg opmerking toe
  9. HVAC Filter Replacement: stap 9, afbeelding 1 van 1
    • Place the new filter into the vent opening. Make sure that it is facing the right direction.
    • There will be an arrow on the side of the filter showing which way to place it.
    Vraag FixBot
    Voeg opmerking toe
  10. HVAC Filter Replacement: stap 10, afbeelding 1 van 1
    • Place vent cover.
    Vraag FixBot
    Voeg opmerking toe
  11. HVAC Filter Replacement: stap 11, afbeelding 1 van 1
    • Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
    • Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
    • Repeat for every screw.
    Vraag FixBot
    Voeg opmerking toe
  12. HVAC Filter Replacement: stap 12, afbeelding 1 van 1
    • Turn on your air conditioner to make sure the filter does not move.
    • If the filter does not move, then you have successfully replaced the filter of your air conditioner.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Anthony Estevez
67 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 2-1, Briggs Fall 2023 Lid van CSU Los Angeles, Team 2-1, Briggs Fall 2023
CSULA-BRIGGS-F23S2G1
5 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 58
Altijd: 889
