Inleiding
Use this guide to remove or replace the outer shell on an HTC Vive.
Wat je nodig hebt
Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
Lift the cover away from the headset and slide it up the cables until it's out of the way.
Lift the HDMI cable straight up to unplug it from the headset.
Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
Use tweezers to remove the small stickers over the four screws securing the outer shell.
Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
4 andere personen hebben deze handleiding voltooid.
5 opmerkingen
I was dusting my pc and in the process tripped over the cable for my vive and cracked the front. Does anyone have an idea on how to get a new outer shell?
I also had the same issue with the front left side getting a crack. I contacted the VIVE support and they said they don’t sell and have no intention on selling parts. Nancy S. suggested sending it in for 6-8 weeks for repair. This option did not work for me so i bought a spare headset on Ebay for parts and did it myself. My advise is to not trust HTC service. I’ve heard many stories of headsets returning over 8 weeks back with nothing fixed.
That’s frustrating to hear. Hopefully the right to repair legislation changes this soon! Not providing parts to your customers is insane.
Richard -
