Ga door naar hoofdinhoud
HTC Touch Pro 2 Housing Replacement
Wat je nodig hebt
  1. HTC Touch Pro 2 Housing Replacement, Battery: stap 1, afbeelding 1 van 3 HTC Touch Pro 2 Housing Replacement, Battery: stap 1, afbeelding 2 van 3 HTC Touch Pro 2 Housing Replacement, Battery: stap 1, afbeelding 3 van 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC Touch Pro 2 Housing Replacement: stap 2, afbeelding 1 van 2 HTC Touch Pro 2 Housing Replacement: stap 2, afbeelding 2 van 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC Touch Pro 2 Housing Replacement, Housing: stap 3, afbeelding 1 van 2 HTC Touch Pro 2 Housing Replacement, Housing: stap 3, afbeelding 2 van 2
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • Potential for device damage: There is a ribbon attached on the back of this part that requires caution to remove.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC Touch Pro 2 Housing Replacement: stap 4, afbeelding 1 van 3 HTC Touch Pro 2 Housing Replacement: stap 4, afbeelding 2 van 3 HTC Touch Pro 2 Housing Replacement: stap 4, afbeelding 3 van 3
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Melinda Phan
438 Reputatie
9 handleidingen geschreven
Cal Poly, Team 9-64, Walters Spring 2011 Lid van Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Leden
27 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 42
Altijd: 4,306
