Ga door naar hoofdinhoud
HTC Thunderbolt LCD/Screen Replacement
Wat je nodig hebt
  1. HTC Thunderbolt LCD/Screen Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC Thunderbolt LCD/Screen Replacement: stap 2, afbeelding 1 van 1
    • Lift and remove the rear panel.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC Thunderbolt LCD/Screen Replacement, Battery: stap 3, afbeelding 1 van 2 HTC Thunderbolt LCD/Screen Replacement, Battery: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC Thunderbolt LCD/Screen Replacement, MicroSD Card: stap 4, afbeelding 1 van 2 HTC Thunderbolt LCD/Screen Replacement, MicroSD Card: stap 4, afbeelding 2 van 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC Thunderbolt LCD/Screen Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
    Vraag FixBot
    Voeg opmerking toe
  6. HTC Thunderbolt LCD/Screen Replacement, Rear Frame: stap 6, afbeelding 1 van 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
    Vraag FixBot
    Voeg opmerking toe
  7. HTC Thunderbolt LCD/Screen Replacement: stap 7, afbeelding 1 van 2 HTC Thunderbolt LCD/Screen Replacement: stap 7, afbeelding 2 van 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
    Vraag FixBot
    Voeg opmerking toe
  8. HTC Thunderbolt LCD/Screen Replacement: stap 8, afbeelding 1 van 1
    • Remove the two Phillips screws where the plastic cover was.
    Vraag FixBot
    Voeg opmerking toe
  9. HTC Thunderbolt LCD/Screen Replacement: stap 9, afbeelding 1 van 2 HTC Thunderbolt LCD/Screen Replacement: stap 9, afbeelding 2 van 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
    Vraag FixBot
    Voeg opmerking toe
  10. HTC Thunderbolt LCD/Screen Replacement: stap 10, afbeelding 1 van 3 HTC Thunderbolt LCD/Screen Replacement: stap 10, afbeelding 2 van 3 HTC Thunderbolt LCD/Screen Replacement: stap 10, afbeelding 3 van 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
    Vraag FixBot
    Voeg opmerking toe
  11. HTC Thunderbolt LCD/Screen Replacement, Rear Inner Frame: stap 11, afbeelding 1 van 1
    • Remove the two Phillips screws securing rear inner frame to device.
    Vraag FixBot
    Voeg opmerking toe
  12. HTC Thunderbolt LCD/Screen Replacement: stap 12, afbeelding 1 van 1
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
    Vraag FixBot
    Voeg opmerking toe
  13. HTC Thunderbolt LCD/Screen Replacement: stap 13, afbeelding 1 van 2 HTC Thunderbolt LCD/Screen Replacement: stap 13, afbeelding 2 van 2
    • Remove the rear inner frame from the rest of the device.
    Vraag FixBot
    Voeg opmerking toe
  14. HTC Thunderbolt LCD/Screen Replacement, LCD/Screen: stap 14, afbeelding 1 van 2 HTC Thunderbolt LCD/Screen Replacement, LCD/Screen: stap 14, afbeelding 2 van 2
    • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
    • Be careful opening these tabs as they are very easy to break.
    • Use a pair of tweezers to pull the capacitive button cable out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  15. HTC Thunderbolt LCD/Screen Replacement: stap 15, afbeelding 1 van 2 HTC Thunderbolt LCD/Screen Replacement: stap 15, afbeelding 2 van 2
    • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
    • Remove the black tape covering the tabs connecting the motherboard and LCD.
    Vraag FixBot
    Voeg opmerking toe
  16. HTC Thunderbolt LCD/Screen Replacement: stap 16, afbeelding 1 van 1
    • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
    Vraag FixBot
    Voeg opmerking toe
  17. HTC Thunderbolt LCD/Screen Replacement: stap 17, afbeelding 1 van 2 HTC Thunderbolt LCD/Screen Replacement: stap 17, afbeelding 2 van 2
    • Once the tabs have been popped up, slowly pull the two pieces away from each other.
    • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
11 andere personen hebben deze handleiding voltooid.
Brandon Younger
212 Reputatie
8 handleidingen geschreven
Cal Poly, Team 19-45, Regan Winter 2013 Lid van Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Leden
48 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 7,243
