Ga door naar hoofdinhoud
HTC One X Plus Motherboard Replacement
Wat je nodig hebt
  1. HTC One X Plus Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
    • The Sim Card Slot is located on the top edge of the device.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC One X Plus Motherboard Replacement: stap 2, afbeelding 1 van 3 HTC One X Plus Motherboard Replacement: stap 2, afbeelding 2 van 3 HTC One X Plus Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC One X Plus Motherboard Replacement: stap 3, afbeelding 1 van 3 HTC One X Plus Motherboard Replacement: stap 3, afbeelding 2 van 3 HTC One X Plus Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Using a Philips head screw driver, remove the five 2.4mm screws that are pictured. Then remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC One X Plus Motherboard Replacement: stap 4, afbeelding 1 van 3 HTC One X Plus Motherboard Replacement: stap 4, afbeelding 2 van 3 HTC One X Plus Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Use the J000 Philips screw driver head to remove the screws as pictured.
    • There are two 3.4mm screws to be removed.
    • Remove the PCB board and the antenna.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC One X Plus Motherboard Replacement: stap 5, afbeelding 1 van 2 HTC One X Plus Motherboard Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using tweezers, disconnect the power button flex cable.
    • Then disconnect the touch screen flex cable.
    Vraag FixBot
    Voeg opmerking toe
  6. HTC One X Plus Motherboard Replacement: stap 6, afbeelding 1 van 3 HTC One X Plus Motherboard Replacement: stap 6, afbeelding 2 van 3 HTC One X Plus Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery from the logic board.
    • Look for a white six pin connector.
    • Remove the battery by pulling upwards.
    Vraag FixBot
    Voeg opmerking toe
  7. HTC One X Plus Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the remaining two flex cables following the same procedure from Step 5.
    • Once these two flex cables have been disconnected, you may now remove the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jason Melo
483 Reputatie
4 handleidingen geschreven
USF Tampa, Team 3-3, Eyestone Fall 2015 Lid van USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 1,524
