Inleiding
If rebooting your device or updating the software to the latest version doesn't solve your Wi-Fi or Bluetooth connectivity, then replace your HTC One X+ antenna.
Wat je nodig hebt
Power off your device.
Insert a pin, paper clip, or very small piece of metal into the hole next to the micro-SIM card holder to remove it.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Now that the rear panel has been removed, use the metal tweezers to carefully remove the antenna.
The antenna is the loose black wire located to the right of the battery.
Using the metal tweezers, connect and install your new antenna, securing the antenna beneath the metal supports.
