Ga door naar hoofdinhoud
HTC One X Antenna Replacement
Wat je nodig hebt
  1. HTC One X Antenna Replacement, Squeeze Test: stap 1, afbeelding 1 van 1
    • Before replacement of the antenna, carry out the squeeze test.
    • Gently squeeze your device between the camera lens and the volume button. This should temporarily reconnect the antenna if it's loose.
    • If the squeeze test doesn't reconnect your wi-fi/bluetooth then move to step 2
    Vraag FixBot
    Voeg opmerking toe
  2. HTC One X Antenna Replacement, Remove SIM card slot: stap 2, afbeelding 1 van 1
    • Insert a safety pin, or other small object into the narrow aperture next to the Sim Card Slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC One X Antenna Replacement, Remove front panel: stap 3, afbeelding 1 van 2 HTC One X Antenna Replacement, Remove front panel: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool, and carefully insert it between the display and rear panel. Separate the two parts.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage or bodily harm.
    • Set aside the rear panel for now
    Vraag FixBot
    Voeg opmerking toe
  4. HTC One X Antenna Replacement, Replace antenna: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Once the rear panel is separated from the front panel, remove the antenna using tweezers.
    • The antenna is located on the right hand side of the front panel as indicated in the image.
    • Replace and reconnect the new antenna in the same position as the faulty one you just removed. Remember to place it underneath the metal supports on the board.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Blain Abebe
769 Reputatie
3 handleidingen geschreven
USF Tampa, Team 4-3, Brown Fall 2014 Lid van USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
3 Leden
26 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 9,829
