Ga door naar hoofdinhoud
HTC One Max Fingerprint Sensor Replacement
Wat je nodig hebt
  1. HTC One Max Fingerprint Sensor Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC One Max Fingerprint Sensor Replacement: stap 2, afbeelding 1 van 2 HTC One Max Fingerprint Sensor Replacement: stap 2, afbeelding 2 van 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC One Max Fingerprint Sensor Replacement: stap 3, afbeelding 1 van 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC One Max Fingerprint Sensor Replacement: stap 4, afbeelding 1 van 2 HTC One Max Fingerprint Sensor Replacement: stap 4, afbeelding 2 van 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: stap 5, afbeelding 1 van 2 HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Andrey Sklyar
452 Reputatie
2 handleidingen geschreven
USF Tampa, Team 11-3, Blackwell Fall 2014 Lid van USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 26
Altijd: 1,606
