Ga door naar hoofdinhoud
HTC One Max Battery Replacement
Wat je nodig hebt
  1. HTC One Max Battery Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC One Max Battery Replacement: stap 2, afbeelding 1 van 2 HTC One Max Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC One Max Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC One Max Battery Replacement: stap 4, afbeelding 1 van 2 HTC One Max Battery Replacement: stap 4, afbeelding 2 van 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC One Max Battery Replacement, Fingerprint Sensor: stap 5, afbeelding 1 van 2 HTC One Max Battery Replacement, Fingerprint Sensor: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. HTC One Max Battery Replacement, Motherboard: stap 6, afbeelding 1 van 2 HTC One Max Battery Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  7. HTC One Max Battery Replacement: stap 7, afbeelding 1 van 2 HTC One Max Battery Replacement: stap 7, afbeelding 2 van 2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
    Vraag FixBot
    Voeg opmerking toe
  8. HTC One Max Battery Replacement: stap 8, afbeelding 1 van 1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. HTC One Max Battery Replacement: stap 9, afbeelding 1 van 3 HTC One Max Battery Replacement: stap 9, afbeelding 2 van 3 HTC One Max Battery Replacement: stap 9, afbeelding 3 van 3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
    Vraag FixBot
    Voeg opmerking toe
  10. HTC One Max Battery Replacement: stap 10, afbeelding 1 van 3 HTC One Max Battery Replacement: stap 10, afbeelding 2 van 3 HTC One Max Battery Replacement: stap 10, afbeelding 3 van 3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
    Vraag FixBot
    Voeg opmerking toe
  11. HTC One Max Battery Replacement: stap 11, afbeelding 1 van 2 HTC One Max Battery Replacement: stap 11, afbeelding 2 van 2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
    Vraag FixBot
    Voeg opmerking toe
  12. HTC One Max Battery Replacement, IR Blaster: stap 12, afbeelding 1 van 1
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
    Vraag FixBot
    Voeg opmerking toe
  13. HTC One Max Battery Replacement: stap 13, afbeelding 1 van 1
    • Pick up and set aside vibrator, do not disconnect.
    Vraag FixBot
    Voeg opmerking toe
  14. HTC One Max Battery Replacement: stap 14, afbeelding 1 van 1
    • Pull out ribbon cable.
    • Peel back infrared sensor.
    Vraag FixBot
    Voeg opmerking toe
  15. HTC One Max Battery Replacement, Camera Board: stap 15, afbeelding 1 van 2 HTC One Max Battery Replacement, Camera Board: stap 15, afbeelding 2 van 2
    • Pull out the secondary board with the camera attached.
    • Be advised of the adhesive on the back.
    Vraag FixBot
    Voeg opmerking toe
  16. HTC One Max Battery Replacement, Remove Bottom Screws: stap 16, afbeelding 1 van 1
    • Remove two screws from the bottom.
    • Set aside metal retaining plate.
    Vraag FixBot
    Voeg opmerking toe
  17. HTC One Max Battery Replacement, Speaker Assembly: stap 17, afbeelding 1 van 2 HTC One Max Battery Replacement, Speaker Assembly: stap 17, afbeelding 2 van 2
    • Pry back the speaker and microphone assembly from the bottom.
    • Be careful to not poke the speaker.
    Vraag FixBot
    Voeg opmerking toe
  18. HTC One Max Battery Replacement, Remove Battery: stap 18, afbeelding 1 van 3 HTC One Max Battery Replacement, Remove Battery: stap 18, afbeelding 2 van 3 HTC One Max Battery Replacement, Remove Battery: stap 18, afbeelding 3 van 3
    • Pry the battery away from the back of the screen with a plastic tool.
    • We recommend using a heat gun to loosen the adhesive holding the battery in place.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
15 andere personen hebben deze handleiding voltooid.
Andrey Sklyar
452 Reputatie
2 handleidingen geschreven
USF Tampa, Team 11-3, Blackwell Fall 2014 Lid van USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Leden
21 handleidingen geschreven
4Gids Commentaar
Microphone in the article, battery in the title.
AaronAndrusko - Antwoord Deel
How to change LCD screen for this model?
Jembalang Tanah - Antwoord Deel
What the &&^& man i prefer to buy another phone %#*@ it
Russel - Antwoord Deel
What the &&^& man i prefer to buy a new phone
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 16,211
