Ga door naar hoofdinhoud
HTC One M8 Display Assembly Replacement
Wat je nodig hebt
  1. HTC One M8 Display Assembly Replacement, SIM Card: stap 1, afbeelding 1 van 2 HTC One M8 Display Assembly Replacement, SIM Card: stap 1, afbeelding 2 van 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC One M8 Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC One M8 Display Assembly Replacement, MicroSD Card: stap 3, afbeelding 1 van 2 HTC One M8 Display Assembly Replacement, MicroSD Card: stap 3, afbeelding 2 van 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC One M8 Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC One M8 Display Assembly Replacement, Rear Case: stap 5, afbeelding 1 van 2 HTC One M8 Display Assembly Replacement, Rear Case: stap 5, afbeelding 2 van 2
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
    Vraag FixBot
    Voeg opmerking toe
  6. HTC One M8 Display Assembly Replacement: stap 6, afbeelding 1 van 3 HTC One M8 Display Assembly Replacement: stap 6, afbeelding 2 van 3 HTC One M8 Display Assembly Replacement: stap 6, afbeelding 3 van 3
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
    Vraag FixBot
    Voeg opmerking toe
  7. HTC One M8 Display Assembly Replacement: stap 7, afbeelding 1 van 2 HTC One M8 Display Assembly Replacement: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool to gently peel up the upper speaker grille.
    Vraag FixBot
    Voeg opmerking toe
  8. HTC One M8 Display Assembly Replacement: stap 8, afbeelding 1 van 1
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
    Vraag FixBot
    Voeg opmerking toe
  9. HTC One M8 Display Assembly Replacement: stap 9, afbeelding 1 van 3 HTC One M8 Display Assembly Replacement: stap 9, afbeelding 2 van 3 HTC One M8 Display Assembly Replacement: stap 9, afbeelding 3 van 3
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
    Vraag FixBot
    Voeg opmerking toe
  10. HTC One M8 Display Assembly Replacement, Headphone Jack/Micro USB Board: stap 10, afbeelding 1 van 2 HTC One M8 Display Assembly Replacement, Headphone Jack/Micro USB Board: stap 10, afbeelding 2 van 2
    • Remove the two silver 2mm Phillips #00 screws securing the battery connector to the motherboard.
    • Use a plastic opening tool to gently pry up the battery connector.
    Vraag FixBot
    Voeg opmerking toe
  11. HTC One M8 Display Assembly Replacement: stap 11, afbeelding 1 van 3 HTC One M8 Display Assembly Replacement: stap 11, afbeelding 2 van 3 HTC One M8 Display Assembly Replacement: stap 11, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a spudger to disconnect the two ZIF connectors.
    • Use the flat end of a spudger to disconnect the black antenna cable.
    • Use a set of tweezers to pull the two ribbon cables free of the ZIF connectors.
    Vraag FixBot
    Voeg opmerking toe
  12. HTC One M8 Display Assembly Replacement: stap 12, afbeelding 1 van 3 HTC One M8 Display Assembly Replacement: stap 12, afbeelding 2 van 3 HTC One M8 Display Assembly Replacement: stap 12, afbeelding 3 van 3
    • Remove the single silver 4mm T5 Torx screw securing the headphone jack/micro USB board.
    • You may need to gently bend the small ribbon cable out of the way to get to the screw.
    • Use a pair of tweezers or a plastic opening tool to gently pry the headphone jack/micro USB board up and out of the phone.
    Vraag FixBot
    Voeg opmerking toe
  13. HTC One M8 Display Assembly Replacement, Display Assembly: stap 13, afbeelding 1 van 3 HTC One M8 Display Assembly Replacement, Display Assembly: stap 13, afbeelding 2 van 3 HTC One M8 Display Assembly Replacement, Display Assembly: stap 13, afbeelding 3 van 3
    • Use the tip of a spudger to disconnect the seven ZIF connectors.
    • Use a pair of tweezers to gently pull the seven ribbon cables free of the connectors.
    Vraag FixBot
    Voeg opmerking toe
  14. HTC One M8 Display Assembly Replacement: stap 14, afbeelding 1 van 3 HTC One M8 Display Assembly Replacement: stap 14, afbeelding 2 van 3 HTC One M8 Display Assembly Replacement: stap 14, afbeelding 3 van 3
    • Use an iOpener to loosen the adhesive securing the display assembly to the rest of the device.
    • Use a suction cup to gently separate the display assembly from the rest of the device.
    Vraag FixBot
    Voeg opmerking toe
  15. HTC One M8 Display Assembly Replacement: stap 15, afbeelding 1 van 3 HTC One M8 Display Assembly Replacement: stap 15, afbeelding 2 van 3 HTC One M8 Display Assembly Replacement: stap 15, afbeelding 3 van 3
    • Carefully guide the display assembly ribbon cable through the midframe for removal.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
70 andere personen hebben deze handleiding voltooid.
Michael Gonzalez
4.448 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-9, Maness Spring 2015 Lid van Cal Poly, Team 5-9, Maness Spring 2015
CPSU-MANESS-S15S5G9
4 Leden
24 handleidingen geschreven
10Gids Commentaar
Great guide - many thanks!
In step 13, you only need to disconnect four ZIF connectors - the top two on the left and top one on the right can be left connected.
Thanks again!
Byrn
Byrn - Antwoord Deel
Be careful when reassembling:
Make sure the power button is put in the right way, it may look symmetrical but it's not! When put in the wrong way it does not work. Check if the shape of the button aligns with the edge of the casing, it's pretty easy to see if you pay attention to it.
Also keep an eye on the back camera. The round black cover glass may shift when trying to click the phone in its casing.
I ended up taking it apart at least 4 times because of this :(
Also, if you want to heat things up you can also use an incandescent light bulb and put your phone over it.
Jan de Vries - Antwoord Deel
position of the square block on the power button is a little bit left from the center (phone facing you with screen)
AG Draaijer - Antwoord Deel
don't follow step 13 in fact &&^& this guide listen to byrn
DeAndre Barron - Antwoord Deel
very helpful, thanks
Stuart Gilks - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 91
Altijd: 55,797
