Ga door naar hoofdinhoud
HTC Hero Trackball Replacement
Wat je nodig hebt
  1. HTC Hero Trackball Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC Hero Trackball Replacement: stap 2, afbeelding 1 van 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC Hero Trackball Replacement: stap 3, afbeelding 1 van 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC Hero Trackball Replacement: stap 4, afbeelding 1 van 2 HTC Hero Trackball Replacement: stap 4, afbeelding 2 van 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC Hero Trackball Replacement, Trackball: stap 5, afbeelding 1 van 2 HTC Hero Trackball Replacement, Trackball: stap 5, afbeelding 2 van 2
    • Remove the two screws near the bottom of the motherboard with a Phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. HTC Hero Trackball Replacement: stap 6, afbeelding 1 van 2 HTC Hero Trackball Replacement: stap 6, afbeelding 2 van 2
    • Gently pull off the ribbons holding the sides of the motherboard to the front enclosure.
    Vraag FixBot
    Voeg opmerking toe
  7. HTC Hero Trackball Replacement: stap 7, afbeelding 1 van 2 HTC Hero Trackball Replacement: stap 7, afbeelding 2 van 2
    • Remove the motherboard from within the front enclosure.
    • Be careful when pulling the ribbons off the motherboard as they may rip or break.
    Vraag FixBot
    Voeg opmerking toe
  8. HTC Hero Trackball Replacement: stap 8, afbeelding 1 van 2 HTC Hero Trackball Replacement: stap 8, afbeelding 2 van 2
    • Tilt the inside of the front enclosure towards your cupped palm to remove the trackball and it's enclosure will fall out.
    Vraag FixBot
    Voeg opmerking toe
  9. HTC Hero Trackball Replacement: stap 9, afbeelding 1 van 3 HTC Hero Trackball Replacement: stap 9, afbeelding 2 van 3 HTC Hero Trackball Replacement: stap 9, afbeelding 3 van 3
    • Position the phone off of the edge of the table and insert the replacement part by inserting the bevel then the trackball into the hole.
    • Make sure the two plastic pins on the trackball bevel are oriented horizontally.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Max Brown
139 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-26, Amido Winter 2012 Lid van Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 35
Altijd: 1,912
