Ga door naar hoofdinhoud
HTC Hero Touch Screen Digitizer Replacement
Wat je nodig hebt
  1. HTC Hero Touch Screen Digitizer Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC Hero Touch Screen Digitizer Replacement: stap 2, afbeelding 1 van 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC Hero Touch Screen Digitizer Replacement: stap 3, afbeelding 1 van 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC Hero Touch Screen Digitizer Replacement: stap 4, afbeelding 1 van 2 HTC Hero Touch Screen Digitizer Replacement: stap 4, afbeelding 2 van 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC Hero Touch Screen Digitizer Replacement, Touch Screen: stap 5, afbeelding 1 van 2 HTC Hero Touch Screen Digitizer Replacement, Touch Screen: stap 5, afbeelding 2 van 2
    • Gently release the two ribbon cables using a plastic opening tool by prying up the pop connectors used to attach the ribbon cables to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. HTC Hero Touch Screen Digitizer Replacement: stap 6, afbeelding 1 van 2 HTC Hero Touch Screen Digitizer Replacement: stap 6, afbeelding 2 van 2
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. HTC Hero Touch Screen Digitizer Replacement: stap 7, afbeelding 1 van 2 HTC Hero Touch Screen Digitizer Replacement: stap 7, afbeelding 2 van 2
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
    Vraag FixBot
    Voeg opmerking toe
  8. HTC Hero Touch Screen Digitizer Replacement: stap 8, afbeelding 1 van 3 HTC Hero Touch Screen Digitizer Replacement: stap 8, afbeelding 2 van 3 HTC Hero Touch Screen Digitizer Replacement: stap 8, afbeelding 3 van 3
    • Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out.
    Vraag FixBot
    Voeg opmerking toe
  9. HTC Hero Touch Screen Digitizer Replacement: stap 9, afbeelding 1 van 3 HTC Hero Touch Screen Digitizer Replacement: stap 9, afbeelding 2 van 3 HTC Hero Touch Screen Digitizer Replacement: stap 9, afbeelding 3 van 3
    • Gently pry out the LCD screen from the top left side of the enclosure using a plastic tool, as illustrated.
    Vraag FixBot
    Voeg opmerking toe
  10. HTC Hero Touch Screen Digitizer Replacement: stap 10, afbeelding 1 van 2 HTC Hero Touch Screen Digitizer Replacement: stap 10, afbeelding 2 van 2
    • Using a plastic opening tool, gently pry the glass from the frame by inserting the flat end between the glass and the frame from the inside of the phone.
    • Follow the edges of the glass to ensure that all the adhesive has been released.
    Vraag FixBot
    Voeg opmerking toe
  11. HTC Hero Touch Screen Digitizer Replacement: stap 11, afbeelding 1 van 1
    • Using a heat lamp or gun, warm the glass to loosen the adhesive binding it to the frame.
    • Once the adhesive has been released, you should be able to remove the glass by pushing on it from the inside of the phone.
    • Be careful to remove the glass slowly. The ribbon cable that connects to the glass is routed through the plastic frame at the bottom.
    Vraag FixBot
    Voeg opmerking toe
  12. HTC Hero Touch Screen Digitizer Replacement: stap 12, afbeelding 1 van 3 HTC Hero Touch Screen Digitizer Replacement: stap 12, afbeelding 2 van 3 HTC Hero Touch Screen Digitizer Replacement: stap 12, afbeelding 3 van 3
    • Carefully feed the ribbon cable through the slot in the plastic frame.
    Vraag FixBot
    Voeg opmerking toe
  13. HTC Hero Touch Screen Digitizer Replacement: stap 13, afbeelding 1 van 1
    • Remove any excess adhesive from the plastic frame.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Max Brown
139 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-26, Amido Winter 2012 Lid van Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 3,831
