Ga door naar hoofdinhoud
HTC HD2 Camera Replacement
Wat je nodig hebt
  1. HTC HD2 Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. HTC HD2 Camera Replacement: stap 2, afbeelding 1 van 2 HTC HD2 Camera Replacement: stap 2, afbeelding 2 van 2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. HTC HD2 Camera Replacement, Midframe: stap 3, afbeelding 1 van 2 HTC HD2 Camera Replacement, Midframe: stap 3, afbeelding 2 van 2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. HTC HD2 Camera Replacement: stap 4, afbeelding 1 van 2 HTC HD2 Camera Replacement: stap 4, afbeelding 2 van 2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
    Vraag FixBot
    Voeg opmerking toe
  5. HTC HD2 Camera Replacement, Camera: stap 5, afbeelding 1 van 3 HTC HD2 Camera Replacement, Camera: stap 5, afbeelding 2 van 3 HTC HD2 Camera Replacement, Camera: stap 5, afbeelding 3 van 3
    • Disconnect the flash cable from its socket in the bottom of the motherboard.
    • Carefully pull the cable from its groove in the frame, working your way back to the camera.
    Vraag FixBot
    Voeg opmerking toe
  6. HTC HD2 Camera Replacement: stap 6, afbeelding 1 van 3 HTC HD2 Camera Replacement: stap 6, afbeelding 2 van 3 HTC HD2 Camera Replacement: stap 6, afbeelding 3 van 3
    • Pull the camera flash and cover off of the board.
    • You may need to peel back the sticker that sits behind the battery.
    • Work carefully. Excessive force can damage the camera or motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. HTC HD2 Camera Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Around the camera is a thin shielding. Remove it with tweezers.
    • Using tweezers, remove the primary camera.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Sam Luedloff
727 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-55, Amido Spring 2011 Lid van Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 43
Altijd: 8,413
