Ga door naar hoofdinhoud
HTC Flyer MicroUSB Port Replacement
Wat je nodig hebt
    1. HTC Flyer MicroUSB Port Replacement, Back Cover: stap 1, afbeelding 1 van 3 HTC Flyer MicroUSB Port Replacement, Back Cover: stap 1, afbeelding 2 van 3 HTC Flyer MicroUSB Port Replacement, Back Cover: stap 1, afbeelding 3 van 3
      • Apply pressure along the bottom of the white panel containing the camera and push upwards.
      • It may take some effort, but it will smoothly slide off.
      Vraag FixBot
      Voeg opmerking toe
    2. HTC Flyer MicroUSB Port Replacement: stap 2, afbeelding 1 van 3 HTC Flyer MicroUSB Port Replacement: stap 2, afbeelding 2 van 3 HTC Flyer MicroUSB Port Replacement: stap 2, afbeelding 3 van 3
      • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
      • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
      Vraag FixBot
      Voeg opmerking toe
    3. HTC Flyer MicroUSB Port Replacement: stap 3, afbeelding 1 van 3 HTC Flyer MicroUSB Port Replacement: stap 3, afbeelding 2 van 3 HTC Flyer MicroUSB Port Replacement: stap 3, afbeelding 3 van 3
      • Remove the black protective piece of plastic by sliding it upwards.
      • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
      • A center 3.5mm Torx screw will be covered by "VOID" sticker.
      • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
      • Remove the protective panel by sliding it upwards.
      Vraag FixBot
      Voeg opmerking toe
    4. HTC Flyer MicroUSB Port Replacement: stap 4, afbeelding 1 van 2 HTC Flyer MicroUSB Port Replacement: stap 4, afbeelding 2 van 2
      • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
      • Use a plastic opening tool to lever up the top half of the cover.
      • Lift the back panel up and remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. HTC Flyer MicroUSB Port Replacement, Battery: stap 5, afbeelding 1 van 2 HTC Flyer MicroUSB Port Replacement, Battery: stap 5, afbeelding 2 van 2
      • Gently unfold the black tape along the top that covers the cable attachment points.
      • Leave the tape partially attached so that it can be easily re-attached.
      Vraag FixBot
      Voeg opmerking toe
    2. HTC Flyer MicroUSB Port Replacement: stap 6, afbeelding 1 van 3 HTC Flyer MicroUSB Port Replacement: stap 6, afbeelding 2 van 3 HTC Flyer MicroUSB Port Replacement: stap 6, afbeelding 3 van 3
      • Use the tip of a spudger as a lever to disconnect the four cable connectors.
      • Gently pull out these cables after releasing the back piece.
      Vraag FixBot
      Voeg opmerking toe
    3. HTC Flyer MicroUSB Port Replacement: stap 7, afbeelding 1 van 1
      • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
      Vraag FixBot
      Voeg opmerking toe
    4. HTC Flyer MicroUSB Port Replacement: stap 8, afbeelding 1 van 3 HTC Flyer MicroUSB Port Replacement: stap 8, afbeelding 2 van 3 HTC Flyer MicroUSB Port Replacement: stap 8, afbeelding 3 van 3
      • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
      • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
      • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
      Vraag FixBot
      Voeg opmerking toe
    1. HTC Flyer MicroUSB Port Replacement, MicroUSB Port: stap 9, afbeelding 1 van 1
      • Use a spudger to unclip the the wires attached to the power jack
      • The clips have a white or black relief tab that, when pressed, releases the wires.
      Vraag FixBot
      Voeg opmerking toe
    2. HTC Flyer MicroUSB Port Replacement: stap 10, afbeelding 1 van 2 HTC Flyer MicroUSB Port Replacement: stap 10, afbeelding 2 van 2
      • Remove the two 2.5mm Torx T5 screws from both sides of the power jack panel.
      Vraag FixBot
      Voeg opmerking toe
    3. HTC Flyer MicroUSB Port Replacement: stap 11, afbeelding 1 van 2 HTC Flyer MicroUSB Port Replacement: stap 11, afbeelding 2 van 2
      • Gently remove the power jack panel.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Joshua
185 Reputatie
1 Handleiding geschreven
USF Tampa, Team 8-5, Leahy Fall 2014 Lid van USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Leden
66 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 1,550
